Multi-dimensional array in VHDL
gnudaemon
Member level 1
Member level 1
vhdl array
How to implement in VHDL such structure like array [][] in C/C++?
Thanks in advance.
@gnudaemon
nand_gates
Advanced Member level 3
array vhdl
Here is one example
array of 16 bit data [128][16]
subtype tmp is std_logic_vector(15 downto 0);
type memory_array is array(integer range 0 to 127, integer range 0 to 15) of tmp;
Hope this helps
gnudaemon
Member level 1
Member level 1
vhdl multidimensional array
How to access each element?
ravi.srivatsa
Newbie level 2
Newbie level 2
vhdl array of std_logic_vector
I just first got the picture of just two dimentional array.
so one example could be
16 bit array[128]
subtype elements is std_logic_vector(15 downto 0);
type 16bit_array is array (0 to 127) of elements;
signal arr : 16bit_array ;
then accesssing the array element could be done by
arr(0) will get first row of 16 bits or one word.
IF it is complicated then for Multidimentional array one can use records and array of records to avoid confusion.
all the best
nand_gates
array in vhdl
variable mem : memory_array;
Then in this case you can access memory as follows
data <= mem(10,10);
Its simple is'nt it?
Mazi3
Full Member level 1
Europe
vhdl two dimensional array
no, no, to acces one element:
type memo is array(0 to 7) of std_logic_vector(23 downto 0);
signal mem:memo;
data<=mem(2)(3);
tesla101
Cheeseland
vhdl 2 dimensional array
since your multidimensional array typically represents a RAM memory there are two possible usages .
as we suppose that you declared your type and signal identically as other users suggested you :
type memory is array (INTEGER range <>) of std_logic_vector(7 downto 0);
signal GetDescDevice : memory(0 to 92); -- a 93 byte character array
to write one byte you'll refer to :
GetDescDevice(3) <= "10110001"; -- you'll write the 4th byte (an 8 bits vector) of your array
to write one particular bit :
GetDescDevice(3)(4) <= '1';
Should help
Regards,
Tesla101
mosgaard2000
Newbie level 3
Newbie level 3
How do you index 1 bit throug the array?
Using the previous example:
I would loke to set bit8 to '0' in all memory adresses.
GetDescDevice(0 to 92)(7) <= '1';
But I get an errormessage saying '0' isn't declared for type std_logic_vector.
Mejdi_tn
Junior Member level 3
multidimensional array vhdl
hi
i have the same probleme! then how to access to data in 2 RAM , and do division between data 1 and data 2
think u
xio
Newbie level 1
Newbie level 1
two dimensional array in vhdl
Something like the following should work :
Set1bit: for i in 0 to 92 generate
begin
GetDescDevice(i)(7) <= '1';
end generate Set1bit;
sns22
Member level 2
Member level 2
Spain
Re: vhdl two dimensional array
i have the same problem..
i want to access the array as a whole in one part of my code and only a single bit of the array in other part of the code.
port(
Switches : out std_logic_vector(7 downto 0);
type register_ram is array (0 to 63) of std_logic_vector (7 downto 0);
signal reg_ram_s :register_ram;
switches(0) <= reg_ram_s(10);
the problem is that here i am tryin to write 8 bits (reg_ram_s 10 signal) to one bit of switches(0)
how to get the one bit from the signal: reg_ram_s(10) ?
---------- Post added at 00:21 ---------- Previous post was at 00:17 ----------
i did it thnks
sizler
Newbie level 1
Newbie level 1
Re: vhdl array of std_logic
16 bit array[128]
all the best
how can we fetch the dta in this type of array? can ny1 xplain ?
vipinlal
Full Member level 6
Full Member level 6
India
Your question has the answer in it. arr(0) will be the first element, arr(1) the second and so on..
If you want to access a particular bit in the 16 bit word then you can use arr(0)(3 downto 0) which will get LSB 4 bits of the first array element.
jhunjhun
Member level 1
Member level 1
shilong
how can i access each element of array
reg [7:0] array[3:0][3:0]
wtr
Full Member level 5
Full Member level 5
Re: array vhdl
Is the following possible?
TYPE track IS ARRAY(0 TO 17) OF BIT;
TYPE side IS ARRAY(0 TO 79) OF track;
TYPE disk IS ARRAY(0 TO 1) OF side;
What I'm trying to achieve it
TYPE 3d_array IS ARRAY (0 TO 1, 0 TO 79, 0 TO 17) OF BIT;
THANKS
TrickyDicky
Advanced Member level 7
Yes, the first example is possible. But it is not the same as the 3d array you posted. Your first one is a 1d array of 1d array of 1d array. What exactly are you trying to acheive. The 3d array you posted is perfectly legal.
I would not recommend making your own array of bit though. There is an array already defined for that (bit_vector).
wtr
Full Member level 5
Full Member level 5
Thanks TrickyDicky. I know that Bit_vector is an unconstrained array, & therefore my first declaration of track is just a subtype of that array.
Given that the disk array declaration is a 1d array of 1d array side of 1d array track.
Is it possible to locate(index) a possition within like you can with a 3d array? Will there ever be a need for such a tree/branch-like structure?
With regards to what i'm trying to achieve...nothing... I'm just curious. There was a exercise in Peter J. Ashenens book "The Students Guide to VHDL" which said
"The data on a diskette is arranged in 18 sectors per track, 80 tracks per side & two sides per diskette. A computer system maintains a map of free sectors. Write a three-dimensional array type declaration to represent such a map, with a '1' element representing a free sector & a '0' element representing an occupied sector. Write a set of nested for loops to scan a variable of this type to find the location of the first free sector."
Which I successfully answered...but it got me curious about cascading arrays.
TrickyDicky
your track type is NOT a subtype of bit_vector. it is a completly new type. Therefore any functions for bit_vector will NOT work with your track type.
a subtype is declared as
subtype track is bit_vector(0 to 17);
To locate an index in a 3d array, you can just write:
result <= disk(a,b,c);
With your 1d array types, it would be:
result <= disk(a)(b)(c);
There are major differences. With the 3d array type, you can only return single bits. You could not return a whole track for example.
With the 1d array types, you can return a whole track, side or bit:
bit <= disk(a)(b)(c);
side <= disk(a)(b);
track <= disk(a);
Reactions: wtr
    wtr
