[SOLVED] MSP430 - Multiple Interrupts on the same port
Andy2k7
Newbie level 3
This is my code so far and I'm not really sure what I should be putting in the switch statement so that when I push the button connected to P1.3 LED0 will be toggled and when I push the one connected to P1.7 LED1 will be toggled.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
#include "io430.h"
#define LED0 BIT0
#define LED1 BIT6
void main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  P1DIR |= (LED0 + LED1);
  P1OUT &= ~(LED0 + LED1);
  P1IE |= (BIT3 + BIT7);
  __enable_interrupt();
  while(1)
#pragma vector=PORT1_VECTOR
__interrupt void Port_1(void)
  switch(P1IFG)
  case ????:
      P1OUT ^= LED0; // P1.0 = toggle;
  case ????:
      P1OUT ^= LED1; // P1.6 = toggle
P1IFG &= ~(BIT3 + BIT7); // P1.3 IFG cleared
doraemon
Super Moderator
Staff member
Japan
Hello!
You cannot do like this, because (also not very probable), 2 interrupts may be in the same vector.
For instance, if P1IFG is 0x88 (bit3 and bit7), it will not be caught by case 0x80 and neither by
case 0x88. The solution is:
if(P1IFG & BIT3) {
    P1OUT ^= LED0;
    P1IFG &= ~BIT3;
if(P1IFG & BIT7) {
    P1OUT ^= LED1;
    P1IFG &= ~BIT7;
By the way, your while loop is useless. It will simply consume
clock cycles and do nothing more. I don't know what __enable_interrupt()
does, but why not using low power mode?
I would write it like this:
#include "io430.h"
#define LED0 BIT0
#define LED1 BIT6
void main( void ) {
	_BIS_SR(LPM0 + GIE);
__interrupt void Port_1(void) {
	__DINT();
	if(P1IFG & BIT3) {
	    P1OUT ^= LED0;
	    P1IFG &= ~BIT3;
	if(P1IFG & BIT7) {
	    P1OUT ^= LED1;
	    P1IFG &= ~BIT7;
	__EINT();
Note that I didn't test it, but I would guess it works.
I have added __DINT an __EINT so that nested interrupts are avoided.
Dora.
Andy2k7
Newbie level 3
Thank you. Your first solution works perfectly I'll look into using low power mode in tonight. Also __enable_interrupt() is the exact same command as __EINT
