chandrumcs
Hi Team,
I used this for blinking RED LED P1.0. But I want to know how to glow the Green alone P1.6.
Please help
Regards,
Chandru
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 #include <msp430g2231.h> unsigned int i = 0; // Initialize variables. This will keep count of how many cycles between LED toggles void main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer. This line of code is needed at the beginning of most MSP430 projects. // This line of code turns off the watchdog timer, which can reset the device after a certain period of time. P1DIR |= 0x01; // P1DIR is a register that configures the direction (DIR) of a port pin as an output or an input. // To set a specific pin as output or input, we write a '1' or '0' on the appropriate bit of the register. // P1DIR = <PIN7><PIN6><PIN5><PIN4><PIN3><PIN2><PIN1><PIN0> // Since we want to blink the on-board red LED, we want to set the direction of Port 1, Pin 0 (P1.0) as an output // We do that by writing a 1 on the PIN0 bit of the P1DIR register // P1DIR = <PIN7><PIN6><PIN5><PIN4><PIN3><PIN2><PIN1><PIN0> // P1DIR = 0000 0001 // P1DIR = 0x01 <-- this is the hexadecimal conversion of 0000 0001 for (;;) // This empty for-loop will cause the lines of code within to loop infinitely { P1OUT ^= 0x01; // Toggle P1 using exclusive-OR operation (^=) // P1OUT is another register which holds the status of the LED. // '1' specifies that it's ON or HIGH, while '0' specifies that it's OFF or LOW // Since our LED is tied to P1.0, we will toggle the 0 bit of the P1OUT register for(i=0; i< 20000; i++); // Delay between LED toggles. This for-loop will run until the condition is met. //In this case, it will loop until the variable i increments to 20000. } }
Please help
Regards,
Chandru
