MSP-EXP430G2 with linux: How to install development tools?
vinodstanur
Advanced Member level 3
Kerala (INDIA)
few days ago , i started learning linux. Now I would like to use the MSP430 Value Line LaunchPad Dev tool in linux.
I checked the link How-to: Launchpad programming with Linux - Hack a Day and followed the steps in that.
Then while installing ,
using
sudo sh buildgcc.sh
I am getting some erroras below)
Do you want to start build right now? (y/n) [n] n
Enter script name to generate
[buildgcc-4.4.5_gdb_7.2.sh]:
build/buildgcc-4.4.5_gdb_7.2.sh created successfully.
Run it now? (y/n) [y] y
--2011-09-03 21:29:53--  http://ftp.uni-kl.de/pub/gnu/binutils/binutils-2.21.tar.bz2
Resolving ftp.uni-kl.de... 131.246.123.4, 2001:638:208:ef1b:0:ff:fe00:4
Connecting to ftp.uni-kl.de|131.246.123.4|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2011-09-03 21:29:58 ERROR 404: Not Found.
sh buildgcc-4.4.5_gdb_7.2.sh exited with status code 8.
vinod@ubuntu:~/mspgcc4$
It seems that the link **broken link removed** is not working now...
Could any one help me?
(also I am new to linux)
---------- Post added at 17:21 ---------- Previous post was at 17:20 ----------
Also, I am using UBUNTU 11.04
---------- Post added at 18:55 ---------- Previous post was at 17:21 ----------
okay,,,Now the problem is solved....
I edited binutil version number in the perl script (buildgcc.pl). In the link ftp.uni-ki.de/pub/gnu , the binutil version is updated and thus I modified the version number in the buildgcc.pl and there after it is installing ....
Any way, I now I am not marking the thread as solved...Because, I am sure , I will be facing some more problem even though the above problem is solved....
