[PIC] MRF24J40MA cannot broadcast message - miwi p2p stack (peer to peer)
wild roze
Member level 2
MRF24J40MA cannot broadcast message - miwi p2p stack(peer to peer)
Hi There,
First of all I wanted to say that I'm new bee to wireless devices.I am trying to build a simple miwi p2p network using PIC18F4550 and MRF24J0MA modules(2 nodes are trying to communicate) using miwi p2p stack.My problem here is I can't broadcast message from one node to other.
here are my basic configurations :
PIC = 48MHZ
SPI = 3 MHZ
Peer to peer not STAR topology
RF interrupt = Enabled
Sleep = Disabled
RESET = 1;
WAKE = 1;​
I'm sure that my SPI works fine,why because I got the anticipated 0XA0 from the module(code given below)
do
        i = PHYGetLongRAMAddr(RFSTATE);
 while ((i&0xA0) != 0xA0);
Code Flow:
The first node starts the connection by MiApp_StartConnection(START_CONN_DIRECT, 10, 0)
and second node establishes the connection via MiApp_EstablishConnection(0xFF, CONN_MODE_DIRECT) function.Both the nodes are set to same PAN ID.
After all these in the first node I try to broadcast a data
                         MiApp_FlushTx();
                         MiApp_WriteData('h');
                          if(MiApp_BroadcastPacket(false)==true)
                              // cursor comes here and the transmission is a success!!
Sadly in the second node I'm unable receive any data..I put break point inside the interrupt
    if(RFIE && RFIF)
         //  but never comes here
I manually checked the external interrupt and it is working fine.
Can anyone help me out in this...I already spent hours in this..Any help would be appreciated.
