MPLAB C30 licence compiler ( full text required )
andre_luis
Super Moderator
Staff member
Brazil
Hi all,
Does anybody have Evaluation Version installed at your PC ?
I searched on the web, but could not find.
Thanks in advance !
They are all the same. If you look at the file size of all three they are identical. I think the distinction only comes depending on which licence you have (if any).
Keith.
Sorry, but same of what ?
I need only read the licence, mentioned at the link above.
for academic use you can download the C compiler free from
There is no licence to download. Simply download the software from the links - either the link you gave or the one from horace1 - they all point to the same software in the end. There are no different versions. If you don't have a licence then it works in "trial mode" for 60 fays where you get all features then works in LITE mode (also called academic) where some optimising features are disabled.
Keith.
It doesn't need uploading on to here - the download links have been posted above.
Keith.
Keith.
Dear Keith,
All compilers, during installing, presents a lecence term.
Generally, it is extracted from a text file ( like, LICENCE.TXT ).
I was just asking if someone could post that to me.
The reason is that I should install prior read the terms.
Due I don´t have Administrator privileges at the corporate Laptop, is not too simple.
Now is clear the problem ?
OK, now I understand. Here it is. I have converted it to TXT - it was RTF.
Keith.
  • LicensePIC24.txt
Thanks a lot !!!
It was very helpfull...
A litlle doubt :
You gave me to the PIC24.
Don´t you have to the c30 ?
Found another which covers both. It is a bit confusing because earlier versions installed in a directory called "mplab c30". Now they install in "mplabc30" Can you spot the difference? No space now!
Keith.
  • License.txt
