mplab-c18 question ..
criss_m
Junior Member level 2
mplab c18
i get this compiller error
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\MCHPFSUSB\fw\Cdc\MCHPUSB.mcs".
Clean: Done.
Executing: "C:\Archivos de programa\MCC18\bin\mcc18.exe" -p=18F4550 /i"C:\Archivos de programa\MCC18\mcc18\src\inc" "main.c" -fo="C:\ARCHIV~1\MCC18\mcc18\temp\main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\MCHPFSUSB\fw\Cdc\main.c:38:Error [1027] unable to locate 'p18cxxx.h'
Halting build on first failure as requested.
BUILD FAILED: Fri Jun 23 09:37:57 2006
what is this option in image mean ????
namqn
Full Member level 3
mplab cdc
Currently, your C18 can not find the header file 'p18cxxx.h' in the include path:
/i"C:\Archivos de programa\MCC18\mcc18\src\inc" you gave it.
That path should read: /i"C:\Archivos de programa\MCC18\mcc18\h", and you can do that by going to Project > Build Options ... > Project, and tab General, browse to that folder for the Include Path, ($INCDIR) text field.
The options in the your image are for optimizations.
Cheers,
criss_m
mplab unable to locate
thanx namqn ,
i can't find a folder called inc ...
Where should it be located , and whats related to...
Thanx for the help...
namqn
Full Member level 3
p18cxxx.h
No, you don't need the folder called 'inc' (apparently, it does not exist).
You need to use the Browse button, and browse to the folder named 'h', in your mcc18 folder. In my computer, it looks like: 'D:\Microchip\MCC18\h'. It is the folder of header files (.h files).
Cheers,
criss_m
error [1027] mcc18
apparently , you can have more than one directory for your include files ... separating the by a ;
i did this , and it worked
C:\Archivos de rograma\mcc18\h;C:\MCHPFSUSB\fw\Cdc
leejok2003
Newbie level 3
mplab ide c18 cannot locate include
i am having the problem as well...how to solve it? i cant find any "general" tab under build options>project...help!!!
Added after 14 minutes:
Problem solved...the name of the header must exactly as in the header folders. e.g in folder "p16f877.h", in the code #include <p16f877.h>
