Mp3 Player problem (mp-fub26)
breneer
Member level 2
atj2075
My sister has a MP3 MPMAN mp-fub26 and the firmware has been corrupted. So it started displaying "starting..."
I have xp sp2 but the http://www.mpmaneurope.com say it has a problem dectecting xp (sp2).
I cant format it or install firmware software because the xp won't detect it.
How can I fix it?
How can i format it, maybe dos???
How can xp (sp2) detect the usb mpman player.
HELP ME.
Thank you very much
mp-fub26
How about fix the problem it in other operation system like win2k,win98 etc.
If you have any forther question ,how about ask the company engineer for help.
mp fub26
Hi Breneer
I was have problem like this my pc not detect my mp3 player but i found very good website and my problem is solved :) and i now play with my mp3 :D
this direct link for solving your problem
SOKRAT
mp-fub26 flash
ANY IDEA
mp-fub26 manual
Hi Breneer
open your mp3 player and tell me if you found this chip or not "ATJ2085 and this hunix hy27uf08 "
SOKRAT
if your mp3 player git what will it still work
chip: atj2075
hunix hy27ua081g1m
atj 2075 firmware
breneer said:
h**p://s1mp3.secret.com.br/en/docs_deadrec.php#ancr3
May be you can further ask the questions to the site provided by SOKRAT. It looks that they are more topic focus then this forum.
mp player problem
Dear Git
I will try to helped you to repair your mp3 player step by step
1- Please tell me if your pc detect your mp3 or not? If not do the flowing
A- Connect your mp3 with USB connector
We must make the ATJ2075 run the recovery mode (in the following steps)
C- Short-circuit with the screwdriver on the memory chip (Recognize the memory
Chip, near the ATJ2075 chip) during startup to simulate a broken
D- When you do this short you will find you pc detect your mp3 player
If you do these steps usefully tell me to do the final steps
SOKRAT
hy27uf08
The Player has ATJ2075 and a Flash SST 39VF010.
Also it has Hynix hy27ua081g1m.
The Hynix Nand Flash Memory or the SST Flash that I will short.
how to short-circuit an mp3 player
atj2075 starting
HIbreneer
short on SST 39VF010 (pins connected with ATJ2075)
Note:
do this short with the screwdriver "if your pc not detect your mp3 player noly !"
untill your pc detect your mp3 player
SOKRAT
mp-fub26 player
if your still stumped there is a great website that is dedicated t omps players avi, etc. it is
www.vcdhelp.com
how to fix mp3 hynix player
sokrat said:
HIbreneer
Note:
SOKRAT
Hi, I have a similar problem. My mp3 can't be detected in XP+SP2, and it can't play. When I turn it on it blinks a red light (ocasionally blue or green or orange).
How do you short cut the memory chip? I hope this will solve my problem.
I have an LG White MP3 player (with Samsung S5L841FXG1L and hynix HY27UG084G2M)
If you need the other markings on the chips, pm me ;)
Thanks in advance
hy27ug084g2m
An MP3 player with a 1GB memory is available for only $8.00US today.
Throw away one that is scratched or does not work.
hnnix hy27uf08
I had my newer player and as usual I broke it but I manage to made it work twice by just doing some flashing, the shorting of pins wasnt needed. Maybe it will do on yours too. Maybe share the model of the player here and other guys might help.
