electrochamp
Hello
In the figure attached below if h Bridge is connected to isolated power supply of 300 volts will the high side mosfet work or not? (as voltage at gate must be around 10volts greater than the drain voltage and in isolated ground our bridge ground will be different so how boot strapping capacitor will get charge to provide 310 volts?)
secondly if i use non isolated topology then my circuit might not work properly? or it will blew away?
#Tahmid
#Tahmid
