[moved] What is the tool used to create .spf file through synopsys?
Sph
Newbie level 1
I need to give the .spf file created as a input to tetramax to induce bridging fault and generate test patterns for identifying the fault.
Xenobius
Member level 5
Re: What is the tool used to create .spf file through synopsys?
Unless otherwise you are using some custom tool, and SPF is nothing more than an image file.
See here
