[moved]vhdl or verilog code to call a function within loop
ecasha
Junior Member level 2
Code Verilog - [expand]
8
9
10
11
module coding(clok,data,coded_out,out,rst);
input [4:0] data;
input clok, rst;
output [1:0] coded_out;
output [1:0] out;
genvar i;
for(i=0;i<=4;i=i+1) begin
   sipo str1 (.din(data[i]),.clk(clok),.dout(out),.reset(rst));
    convol_enco u3 (.coded(coded_out),.in(data[i]),.p_out(out));
    end
endmodule
what is the problem with above code? how do i rectify it?
How do you expect this to work when the loop is unrolled and all the outputs of the five (0-4) instances of u3 are all shorted together?
I think you are probably misinterpreting the code and think the loop is done sequentially in time and that you get 5 outputs one after another.
