preethi19
Full Member level 5
Hi i designed a simple circuit and i saved the output current and i am able to see the current value and the region of the transistors in print annotate. so the circuit has no problem in functioningcorrectly. But the output waveform window is blank. I chose the transistor drain as the output to be plotted and i am getting error "Trying to plot expression .... which does not evaluate to an object that can be plotted". Can anyone pls help me!!!
