[MOVED] Tiny210V2 S5PV210 ARM Cortex-A8 Samsung single board
armdevs
Newbie level 3
The Tiny210V2SDK is a high-performance design based on the Samsung S5PV210 ARM Cortex-A8 microcontroller with 512MByte DDR2 RAM, 2GByte Nand Flash, RTC, Audio and Ethernet capability. The system consists of a motherboard with the CM-Tiny210V2 CPU module plugged into it, and an LCD touchscreen module mounted (three sizes available). The motherboard has integrated RS232, USB, Ethernet, Audio In/Out, Keyboard, LCD, HDMI, TV out, camera in, SDIO WiFi Module (pins only), SD card, G-Sensor and more other functions on board.
A complete software development package is included. The board supports Linux 2.6.35 Android 4.0 and Android 2.3 operating system and is provided with complete basic drivers.
1GHz Samsung S5PV210 with PowerVR SGX540 graphics engine
512MB DDR2 RAM and 2GB NAND Flash
LCD/Touch Screen, HDMI, TV out, Audio support
SDIO, USB Host/OTG support
Ethernet, WiFi, serial port, G-Sensor, GPIO
Contains CPU board and motherboard
Linux 2.6.35 & Android 2.3 support (Android 4.0 will be supported; includes test demo)
HardWare
CPU Module-CM-Tiny210V2 CPU module
1 GHz Samsung S5PV210 with PowerVR SGX540 graphics engine
512MB DDR2 RAM, 32-bit data bus, 200 MHz
MLC NAND Flash: 2GB
Two 60-pin and two 30-pin 2.0mm spaced DIP connectors for mounting to motherboard
Ethernet Chip: DM9000AEP
Audio Codec Chip: WM8960
Four user LEDs (green)
Supply voltage from 2V to 6V
CPU module dimensions: 74x 55 x 11mm
Software: Android 4.0, Android 2.3, Linux 2.6.35, Qtopia-2.2.0/Qt-4.4.3/Qt-4.7
Mother board
We provide the Tiny210V2SDK mother board for CM-Tiny210V2 CPU board.
1. Integrated USB 2.0 Hub: Extended 4 USB host ports, three of them as the standard side port, and one was lead by SCON interface
2. AV CCD Camera In: Integrated TVP5150 video chip: 2 AV input port (RCA), can be directly connected using a CCD camera
3. Expand MiniPCI interface: expand 3G Module
4. Serial Port: 4 serial port, two of them have been converted to RS232, and leads through the DB9 Block (COM0, COM1), through the CON1, 2, 3, 4, Block leads to TTL level
5. keys: 8 key
6. RJ45 Ethernet port: using DM9000AEP(On CPU board), 10/100M adaptive
7. Audio input and output: using the WM8960 professional audio chip(On cpu board), containing Class D amplifier on-board microphone, and supports HDMI audio and video synchronization output
8. USB Slave: 1 Road, the USB 2.0 specification
9. Buzzer: 1, control by the PWM0
10. EEPROM: AT24C08 (256 Byte) for I2C test
11. LCD Interface: 2 LCD interface, support 3.5 "-19" full color TFT display LCD
12. Capacitive touch screen: I2C-based interface, on the 45Pin LCD connector
13. Resistive touch screen: 1-wired Touchscreen interface, On 40Pin LCD connector
14. SDIO interface: used to connect the SD WiFi module and other
15. CMOS Camera interface: used to connect CMOS camera
16. RTC clock: with a backup battery (according to different regions or time periods, mailing may remove the battery)
17. Gravity sensor Support
18. PCB layer: 2
19. PCB size: 180 x 130mm, can be easily fixed all kinds of LCD modules, especially the 7-inch LCD module
20. Power supply: DC-5V
For more details please refer to: http://armdevs.com/Tiny210V2-S5PV210.html
Website: www.armdevs.com
Email: sales@armdevs.com
