[Moved]: Power Amplifier Terminologies
shemo
when it says delivering 18dBm is that 18dB per microwatt?
why is power in positive dBm and whereas noise is generally in negative dB?
ACPR(adjacent channel power rejection) at 550kHZ offset is -21.4dBc
what's this ACPR? why at 550kHZ? what's dBc?
what's Frequency Offset/kHZ?
why generally, most power amplifier operate near 1dB compression point in order to achieve highest effiency?
And linearity is measured with third order harmonic intercept and 1dB compression point of fundamental frequency.
I can understand fundamental frequency but why pay attention to only third order instead of other orders?
PatrickPribyl
Newbie level 5
dBm is dB relative to 1 milliwatt. Power can be any value relative to 1 mW, so positive or negative dB. Noise should hopefully be lower than signal, so the ratio 10*log(Pnoise/Psignal) should be negative for a useful device.
One rating manufacturers give in the specs is for the "full scale" power output, which is more or less the maximum power available. This is the power at which the output stage just begins to saturate, i.e. Vout/Vin is 1 dB smaller than it would be at lower input levels, or 1 dB "compression". They frequently mention 3 dB compression as well, meaning even more saturated. Roughly speaking, at this level the amplifier is close to operating with the output transistors are either fully on or fully off, so they have the least dissipation. Operation at this level also begins to generate harmonics, because the output waveform is no longer sinusoidal.
I think they usually give 3d order harmonic intercept as a point of comparison between amplifiers. This is (likely) the biggest harmonic when there is only modest distortion of the output waveform.
I know less about ACPR, perhaps someone else will contribute here. What I can offer is that these amplifiers can be used in communications schemes where there are several carrier frequencies (channels) propagating along the same wire. It is useful to know how much crosstalk will be generated by the amplifier when it is used to amplify the composite signal. Presumably for the manufacturer's intended application, 550 kHz is the channel separation in frequency. E.g. for a 50 MHz carrier, the next channels might be 50.550 MHz, 51.1 MHz, etc. I assume that -21.4 dBc means that the adjacent channel has some signal leaking in from the carrier at a level given by 10*log(Padj/Pc) = -21.4.
FvM
Super Moderator
Staff member
Bochum, Germany
I believe that most questions can be already answered by brief look at Wikipedia.
Partly you may be asking the wrong questions. Adjacent power rejection is usually not a problem of the amplifier, at least in a typical application where the power amplifier bandwidth is considerably larger than the transmitted signal. It's rather a problem of transmitter signal generation, either due to excessive modulator bandwidth or spurious PLL signals. But it probably doesn't help much to discuss terms, you need to understand how transmitter signal generation and amplification works and which problems are involved. "c" in dBc means carrier, -20 dBc means 20 dB below carrier level. The specification is often used for harmonics and sidebands.
A PA with symmetrical design (e.g. push-pull amplifier) will mostly expose odd order harmonics and IM components. 3rd order IP is the most critical then.
