[moved] PCB finish for High Speed pcb
senilicus
Full Member level 5
Amsterdam / The Netherlands
Hello all,
At the moment I am working on a design that carries several high speed signals, (40Mbit, 10Mbit). There is no soldermask on these traces and
we need a finish for those traces.
ENIG or ENIPIG are not possible because of the nickel and immersion silver wil oxidate over time.
One of the possible finishes could be Electroless Palladium/Autocatalytic Gold (EPAG, EPIG)) but this appears to be a finish that not much
pcb manufacturers offer.
Any suggestions?
What a mistake I made.
The signals are 40Gbit an 10Gbit. a bit faster.
It's best to avoid microstrip transmission lines for 40 Gbps applications. Use stripline transmission lines. Then you don't need to worry about surface finish.
