[moved] New arrivals-1.08, 1.3, 2.1 inch HMI round knob display solutions
Team Source Display(TSD) is a professional LCD display manufacturer from China with ISO13485,IATF16949,ISO9001 and other certificates. We have been specialized in LCD display industry for more than 18 years. We are specializing in TFT LCD display, monochrome LCD display, OLED display, capacitive touch screen, resistive touch screen, etc. We have some standard modules, and we also support custom displays, if you have any project need displays, we are glad to provide support.
Recently, we have launched a new HMI round knob display, just as follows:
This is a knob display, since it equipped with a rotating switch. There are multiple levels of menus on the display, when you turn on the display, this is the first-level menu, we can control the options of the menu by rotating the knob, and pressing down can confirm the options to enter the second-level menu, press again to enter the third-level menu, long press for 15 seconds to return to the first-level menu.
This is a new design in the field of smart home, which can be used for coffee machine, washing machine, microwave, smart stove, etc. The compact display can reduce the space occupied by the display, thereby reducing the volume of the end product. In addition, the surface of this display has a cover lens, which is waterproof. The shell of the display can also be made into various colors, such as red, blue, and there are special effects lights at the bottom, which are very fashionable and beautiful.
Below are some important specifications of this display:
1) CPU: CPU ARM Cortex-M0
2) Storage: 128Mbit norFlash (available to be customized)
3) Power supply: DC 5V,500mA
4) Operation Type: Rotate, Press
5) Ambient light: RGB three-color light circle at the bottom, can be customized
6) Appearance: aluminum alloy car anodized sandblasting, black/white optional, cover glass 2.5D/2.0D optional
7) Operating temperature: -20~70°C
8) Storage temperature: -30~80°C
The most important thing is that this display is UART interface, we can provide a complete set of solutions, you can use it directly as long as it is connected to the power supply. In other words, you do not need to do secondary development or design your motherboard after receiving the displays, you can use it directly.
By the way, for this round knob display solution, we have ready-made designs for 1.08 inch, 1.3 inch, 2.1 inch now. If you think the design is suitable for your project, you need to send your UI material (the picture, words that you want to display on the screen) and menu list to us only, then we will help finish the design, and you can use this display directly after received it.
If you are interested in this round knob display solution or want to know more information, please feel free to contact us, we are always here for you.
