[Moved] Need Help on a 100w Inverter 220v
Rambo55
Banned
Australia
I have check everything on this Inverter but to me Mosfet power is better it seem to me I all ways have bad luck on transistor Inverter can some one tell me is there are fault in this Schematic as when I put the Fuse in it blows and the light come on and go out. Send a Email
Re: Need Help on a 100w Inverter 220v
Hello don't ask to send mail this is a great open forum.all doubts and answer only through the forum .else moderator may warn you.
this circuit is from old efy, and works fine , you can use Sl100 in place of Q1 and Q2
Hello,
Before placing loadfuse check the CD4047 output for pulsed DC, may be faulty IC leads to saturate output transistors resulting in short circuit. check the pot for sufficient time base it may also lead to draw more current.
