[Moved]: Monte-Carlo simulation in cadence- error
akchetana
Newbie level 5
Hello all,
I am working on an SRAM cell for which I have to perform monte-carlo simulation.
During MC simulation in ADEXL window, we found a pop up window with the following error messages after 10 min, while the 6T SRAM cell was run for 100ns for 2 samples. Please help in this matter.
[Error message
ADEXL-1921: failed to start new job after 3 attempts . Possible reasons could be
1. The macnie selected in the current job set up policy is not reachable
2. The cadence hierarchcy is not detectedd, not installed properly, or not compatible on the machine selected in the current job set up policy.
3. Job start script /home/student/chetna/.temp_student/.cmddir0/runICPR3 is not found in the remote machine.
Do you want to retry with the current set up? Selecting no will abort the current session. ]
However it is working when we try to simulate using .ocn script.
Thanks.
erikl
Super Moderator
Staff member
Germany
Did you try it once more? Perhaps just one of the farm machines wasn't accessible.
akchetana
Newbie level 5
Thank you for your response.
Yes I have tried it many times. I have even tried for other corner analysis. It is not working for any analysis in ADE-XL.
However I have tried this using ocean script L, where I found it working. What would be wrong with ADE-XL ?
Thanks.
Dominik Przyborowski
Norway
Check in logs of ade xl and vnc also. I assume that You don't run virtuoso on the only blessed by Cadence Linux distribution?
dick_freebird
Advanced Member level 5
USA
So I guess Ocean in command line mode don't need
no steenkin' ADEXL license. Which maybe you've got
one less of, than you need.
Or, license service lag is "unacceptable" and times
out. Maybe increase the timeout if you can, and
see what the license server has been doing when
it should've been making your sammich. How you'd
do this I have no idea.
