shanmei
Advanced Member level 1
Do you know how to build a low power linear voltage to current converter? The voltage to current conversion needs to to very high precision, like 10bit resolution.
This opamp based V/I is good, but the opamp will consume large power consumption. Since I need a fast response Voltage to Current, the opamp needs to be large bandwidth to follow the input voltage change.
The other schematic is good, but the linearity is not so good as the opamp based one.
Do you have any other idea to build a low power fast voltage to current converter ? Thanks.
