sys_eng
Full Member level 4
1)I fail to see how does that 2 current sources become DAC for offset correction.
Anyone has any idea on this?
Here's the text for this latch
When clk is low, the latch resets and its outputs are pulled high. When clk rises,
node S is switched low, and the inputs are amplified onto nodes bM and bP, causing one
to fall more rapidly. The cross-coupled inverters then regeneratively amplify to full swing.
The current-mode DAC is connected to internal nodes of the latch, so it has no effect on
the input capacitance, and only slightly slows the regeneration of the latch.
