adiishamz
Newbie level 5
i want someone to design and develop a PCB compossed of Sim300dz and Atmega32l (atmel) connected togather with load at atmega32's output.
The purpose is to use sim300dz as a module to send and recieve text message and further pass the message information to microcontroller(atmega32l AVR) which will switch the load circuit according to the information which was sent in the text. All the switching operations will be pre-defined in the programming so the microcontroller will just compare the recieved text with saved switching strings and respond accordingly at its output which will be connected to relay switches to control loads.(On & Off)
Requirements are as follow:-
i) Finalized PCB with all components(ready to use)
ii) Program wrote in C language to send and recieve data from Sim300dz(Hex files etc)
iii) PCB layouts
iv) Schematics
v) components details(used on PCB)
Note: Usage of following Modules is must :-
-Sim300dz (no other version)
-atmega32L AVR (atmel)
only reply if u can design this within 2-3 weeks Maximum.
Regards
more details will be provided upon rquest.
iii) PCB layouts
iv) Schematics
Regards
