library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity i2c_eeprom is
Port ( clk : in STD_LOGIC;
scl : out STD_LOGIC;
sda : inout STD_LOGIC);
end i2c_eeprom;
architecture Behavioral of i2c_eeprom is
signal counter : integer:=0;
signal state : integer:=0;
signal delay : std_logic:='0';
signal data : std_logic_vector(7 downto 0):=x"41"; -- Data to be write into the EEPROM
signal slave_addr : std_logic_vector(7 downto 0):=x"A0";-- Slave address and which indicates data is going to write on EEPROM
signal internal_addr : std_logic_vector(7 downto 0):=x"00";-- Internal address of EEPROM to store the data
signal i : integer:=7;
begin
process(clk)
begin
if rising_edge(clk) then
counter<=counter+1;
if counter=119 then -- Total count for 100 KHz
counter<=0;
delay<=not delay;
end if;
end if;
end process;
process(delay)
begin
if rising_edge(delay) then
state<=state+1;
case state is
----------------------------- Start condition--------------------
when 0=>
scl<='1';
sda<='1';
when 1=>
sda<='0';
when 2=>
scl<='0';
------------------------ Sending slave address ie.) x"A0"---------------------------------------------
when 3=>
sda<=slave_addr(i);
scl<='1';
when 4=>
scl<='0';
if i=0 then
i<=7;
state<=5;
else
i<=i-1;
state<=3;
end if;
when 5=>
scl<='1'; -- Checking ack
when 6=>
scl<='0';
-------------------- Sending internal address ie). x"00"-----------------------------
when 7=>
sda<=internal_addr(i);
scl<='1';
when 8=>
scl<='0';
if i=0 then
i<=7;
state<=9;
else
i<=i-1;
state<=7;
end if;
when 9=>
when 10=>
scl<='0';
--------------------- Sending data 'A' ie). x"41" --------------------
when 11=>
sda<=data(i);
scl<='1';
when 12=>
scl<='0';
if i=0 then
i<=7;
state<=13;
else
i<=i-1;
state<=11;
end if;
when 13=>
when 14=>
scl<='0';
-------------------------- Stop condition ----------------------------------------
when 15=>
sda<='0';
scl<='1';
when 16=>
scl<='1';
sda<='1';
when 17=>
scl<='0';
when others=>
end case;
end if;
end process;
end Behavioral;
