[moved] How to use A USB flash drive on a Windows PC
netac
Newbie
China
A USB drive, also known as a flash drive or memory stick, is a small portable device that plugs into a COMPUTER's USB port. USB drives are commonly used for storage, data backup, and file transfer between devices. USB drives have a variety of storage capacities and different ports, each with a unique shape. Depending on the type of computer you are connecting to, using a USB drive may vary. Read on to learn how to use USB drives on Windows.
Is my USB drive compatible with my computer?
If you are using a USB drive for the first time, be sure to check that your USB drive is compatible with the USB port on your computer. Most people will recognize USB-A, the large square USB drive that can only be plugged in one way. However, the latest Windows computers are starting to replace usB-A ports with smaller, slimmer alternatives to USB-C ports.If your Windows computer only has USB-C ports, but your USB drive is A USB-A type drive, then you can either purchase A USB-A to USB-C adapter, or for A little money, you can purchase A new USB-C drive.
How do I insert a USB flash drive?
With a USB drive compatible with your Windows computer, you can now plug the drive into the USB port. These ports are typically located on the side of a laptop and the front or back of a desktop. If you are using USB-A, be sure to insert the USB drive in the correct way to avoid damaging your computer.
When the USB drive is first inserted, Windows will install the necessary driver software to use the USB drive. Next, a dialog box should appear. Select Open folder to view files. If the dialog box does not appear, you can fix it by inserting the USB drive again or opening File Explorer and selecting your USB drive.
How do I format a USB drive on Windows 10?
Most USB flash drives will be preformatted. If the drives are 32GB or less, they will be in the FAT32 file system. If they are larger than 32GB (for Kingston's USB flash drive capacity set, this would be our 64GB capacity or higher), they will be located in the exFAT file system. FAT32 is limited to a maximum storage volume of 32GB, so it cannot format this file system on any storage drive larger than this.
After you plug the USB flash drive into your computer, you can copy and move files, format, or rename the drive. You can rename the drive by opening File Explorer and clicking This PC in the left pane. Then right click on your USB drive and choose Rename. NTFS is the standard format for Windows boot drives, but external Windows exFAT or FAT32 allows you to use USB drives on Mac and Windows computers. You may want to keep the drives as exFAT or FAT32 so they can be used with the Mac, but you can also format them as NTFS file systems. To format to NTFS, open File Explorer, and click This PC in the left pane. Then right click on your USB drive and select Format and NTFS, but be aware that all data on the drive will be deleted, so make sure you have another copy.
If the USB flash drive has been formatted for Mac (AFS+) but you want to use it on your PC, you must format it as an exFAT, FAT32, or NTFS file system, but note that all data on the drive will be deleted.
After formatting the USB drive, it should be ready to use. You can view the contents by opening File Explorer and selecting your USB drive from the list on the left panel.
How do I use a USB drive?
Once you have access to the USB drive on your Windows computer, you can now use it just like any other folder on your computer.You can save documents directly to a USB drive.You can copy files to or from USB drives. (Please note that when you copy a file, the file will be copied).You can also delete files from your USB drive by dragging them to the trash. A dialog box should appear. Click Yes to confirm that you want to permanently delete this file and free up storage on your USB drive. (If the dialog box does not automatically appear; Right-click the recycle bin, then click properties, and check the show Deletion confirmation dialog box.
How do I remove a USB drive?
After using the USB drive, be sure to properly remove the device from the Windows computer to avoid file damage. You can do this by clicking the small arrow on the right side of the taskbar, selecting the USB icon, and then clicking 'Eject' in the pop-up menu of the desired USB or right-clicking on the USB drive and selecting 'Eject'.
External storage such as USB drives and SSDS is a great way to transfer files, back up important documents, and give A Windows computer some extra space to run applications and play games.
