My circuit is a simple half wave rectifier. I have designed the circuit in Proteus and have added graph to display AC voltage and DC voltage but I am not able to add Power trace to graph.
There is a feature called Add Transient Trace but I don't know how to use it.
Can somebody modify my Proteus file and add the power trace to graph. It should show output voltage * output current and also it should show output voltage and output current in the same graph.
What I tries: I added output voltage probe and current probe and added them to graph and then added a trace called P with the expression P1*P2 but it doesn't give power graph.
What should I do ? Should I remove the ground connection ? If I remove the ground connection then in Virtual Oscilloscope it shows Vac but in graph current doesn't plot. It remains 0 always.
It is only considering one 2.2R and calculating current. Without ground connection it doesn't plot current.
If one 2.2R is considered then graph data is correct.
