[SOLVED] [Moved] [Help Urgent]Problem with AMS Hitkit 3.7 Installation with Mentor Graphics
univer_solar
Member level 4
Dear All,
I installed AMS Hitkit ver 3.70 for Mentor Graphics but I couldn't start the program by using the command:
ams_icstudio -project project_name -tech c35b4c3
ams_icstudio: command not found
Before install AMS, I already used UMC18 and IC-DA worked very good. I also configured the environment variables as following:
# Design Kit Environmental Variables #
# notes: 1. <target_dir> = /home/***user***/mgc
# 2. <path_install_dir> = /home/***user***/mentor
export M_MGC_HOME=/home/user1/mgc
export MGC_HOME=$M_MGC_HOME/2008.2e_rhelx86linux/icflow_home
export MGC_AMS_HOME=$M_MGC_HOME/ams_home
export PATH=$PATH:$MGC_HOME/bin:$MGC_AMS_HOME/bin:$M_MGC_HOME/calibre/ixl_cal_2010.1_22.19/bin:/home/user1/ams/programs/bin
export MGC_WD=/home/user1/workspace
#This setup part is for UMC18
export MGC_DESIGN_KIT=`pwd`
export MGC_LOCATION_MAP=$MGC_DESIGN_KIT/mgc_location_map
export AMPLE_PATH=$MGC_DESIGN_KIT/userware
export MGC_ICSTD_LIB=$MGC_HOME/mgc_icstd_lib
export MGC_IC_DEVICE_LIB=$MGC_ICSTD_LIB/device_lib
export MGC_IC_GENERIC_LIB=$MGC_ICSTD_LIB/generic_lib
export MGC_IC_SOURCES_LIB=$MGC_ICSTD_LIB/sources_lib
export MGC_MACROLIB=$MGC_ICSTD_LIB/mgc_ic_macrolib
export MGC_IC_COMMLIB=$MGC_ICSTD_LIB/mgc_ic_commlib
export MGC_IC_COMMLIB_QS=$MGC_ICSTD_LIB/mgc_ic_comm_qs
export MGC_IC_COMMLIB_RF=$MGC_ICSTD_LIB/mgc_ic_comm_rf
export MGC_IC_VERILOG_LIB=$MGC_ICSTD_LIB/mgc_ic_verilog
export NCF_GLOBAL=$MGC_ICSTD_LIB/global.ncf
export MGC_CALIBRE_DRC_RUNSET_FILE=$MGC_DESIGN_KIT/Calibre/DRC/DRC.runset
export MGC_CALIBRE_LVS_RUNSET_FILE=$MGC_DESIGN_KIT/Calibre/LVS/LVS.runset
#This setup part is for AMS tech.
export AMS_DIR=/home/user1/ams
export AMS_AMPLE_PATH=/home/user1/ams/mentor/userware_ics
export AMS_NCF_GLOBAL=/home/user1/ams/mentor/as_global.ncf
export AMS_IC_LIB=/home/user1/ams/mentor/ic_station/c35/libraries
export AMS_IC_RULES=/home/user1/ams/mentor/ic_station/c35/rules
export AMS_IC_PROCESS=/home/user1/ams/mentor/ic_station/c35/process
# for getting the license from the server (license for the tools)
export MGLS_LICENSE_FILE=1717@192.168.84.2
Please help me to solve this problem. Thanks so much.
alexan_e
Administrator
Greece
I think you should ask Mentor Graphics support to help with the license settings, they should be able to tell you what to do
Alex
univer_solar
Member level 4
Hi alexan,
This is not the tool problem but the library foundry installation problem. So Mentor will not support.
