[moved] Help in writing a testbench for VHDL code
xiaoanime
Newbie level 2
This is the vhdl code I had, I am not sure how write a test bench for it. Anyone able to guide me through this?
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity ltp_controller is
port (
iCLK:              in  std_logic;  -- LCD display clock
iRST_n:            in  std_logic := '0';  -- system reset
-- SDRAM Side
iREAD_DATA1:       in  std_logic_vector (15 downto 0); -- R and G
iREAD_DATA2:       in  std_logic_vector (15 downto 0); -- B
oREAD_SDRAM_EN:    out std_logic;  -- read sdram data control signal
-- LCD SIDE
oHD:               out std_logic;  -- LCD Horizontal sync
oVD:               out std_logic;  -- LCD Vertical sync
oDEN:              out std_logic;  -- LCD DataEnable
oLCD_R:            out std_logic_vector (7 downto 0);  -- Red out
oLCD_G:            out std_logic_vector (7 downto 0);  -- Green out
oLCD_B:            out std_logic_vector (7 downto 0)   -- Blue out
end ltp_controller;
architecture behave of ltp_controller is
constant H_LINE:                natural := 1056;
constant V_LINE:                natural := 525;
constant Hsync_Blank:           natural := 46; -- H_SYNC + H_Back_Porch
constant Hsync_Front_Porch:     natural := 210;
constant Vertical_Back_Porch:   natural := 23; -- V_SYNC + V_BACK_PORCH
constant Vertical_Front_Porch:  natural := 22;
-- ieee.numeric_std.all start
signal x_cnt:           unsigned (10 downto 0);
signal y_cnt:           unsigned (9 downto 0);
signal read_red:        std_logic_vector (7 downto 0);
signal read_green:      std_logic_vector (7 downto 0);
signal read_blue:       std_logic_vector (7 downto 0);
signal display_area:    std_logic;
signal mhd:             std_logic;
signal mvd:             std_logic;
signal mden:            std_logic;
begin
oread_sdram_en <=
'0' when x_cnt > Hsync_Blank - 2  and  -- 214
x_cnt < H_LINE - Hsync_Front_Porch - 1 and -- 1015
y_cnt > Vertical_Back_Porch - 1 and  -- 34
y_cnt < V_LINE - Vertical_Front_Porch else -- 515
'1';
display_area <=
'1' when x_cnt > Hsync_Blank - 1 and -- > 215
x_cnt < H_LINE - Hsync_Front_Porch and --  < 1016
y_cnt < V_Line - Vertical_Front_Porch - 1 else
'0';
read_red <=     iREAD_DATA2(9 downto 2) when display_area = '1' else
(others => '0');
read_green <=   iREAD_DATA1(14 downto 10)  & iREAD_DATA1(14 downto 12)
(others => '0');
read_blue <=   iREAD_DATA2(9 downto 2) when display_area = '1' else
(others => '0');
X_COUNTER:process (iRST_n, iCLK)
begin
if iRST_n = '0' then
x_cnt <= (others => '0');
elsif rising_edge(iclk) then
if x_cnt = H_LINE - 1 then
mhd <= '0';
else
x_cnt <= x_cnt + 1;
mhd <= '1';
end if;
end if;
end process;
Y_COUNTER:process (iRST_n, iCLK)
begin
y_cnt <= (others => '0');
if y_cnt = V_LINE - 1 then
else
y_cnt <= x_cnt + 1;
end if;
end if;
end if;
end process;
LCD_VSYNC:process (iCLK, iRST_n)
begin
mvd <= '1';
elsif rising_edge(iCLK) then
if y_cnt = 0 then
mvd <= '0';
else
mvd <= '1';
end if;
end if;
end process;
LCD_ENAB:process (iCLK, iRST_n)
begin
mden <= '1';
if display_area = '1' then
mden <= '1';
else
mden <= '0';
end if;
end if;
end process;
BLANK_RESET:
begin
oHD <= '0';
oVD <= '0';
oDEN <= '0';
oLCD_R <= (others => '0');
oLCD_G <= (others => '0');
oLCD_B <= (others => '0');
oHD <= mhd;
oVD <= mvd;
oDEN <= mden;
oLCD_R <= read_red;
oLCD_G <= read_green;
oLCD_B <= read_blue;
end if;
end process;
end architecture;
There are plenty of tutorials out there. Use google to find one.
The concept it simple - you use your entity as a component and inject it with software generated stimuli. You then observe the behavior of the design as it responds to the given stimuli.
As TrickyDicky mentioned - there's a lot of information available.
Try this:
https://www.youtube.com/results?search_query=vhdl+testbench+tutorial
Also, you can use an automatic testbench generator (available in Active HDL) and learn from it.
