[MOVED] Even binary counter from binary counter...................
sunidrak
Full Member level 1
Full Member level 1
Bengaluru, India
hi ,
can anybody tell how to design or modify a binary counter(0,1,2,3,...) as a even counter counting (0,2,4,6....) ??
regards
Sunil
Re: Even binary counter from binary counter...................
Hi Sunil,
At what level do you design?
In general, append an additional bit with 0 value to the output of the binary counter.
For example, if you had 10-bit binary counter, you'll have 11-bit counter. LSB bit will be tied to 0.
assign cnt_out = {counter, 1'b0};
Regards,
Vardan
hi vardan Sir,
I have a 4 bit binary counter , i want to modify it as a "even counter", means it should count only 0..2...4...6...8.....14..
you can just multiply normal binary number with 2'b10
Is this related to CPLD/FPGA or hips of the 4000 or 7400 series ?
This is binary counter output sequence:
0000, 0001, 0010, 0011, 0100,...
0 , 1 , 2 , 3 , 4 ,...
Just add a bit after LSB of the counter above, and tie it to 0.
00000, 00010, 00100, 00110, 01000,...
0 , 2 , 4 , 6 , 8 ,...
initialize out= 4'b0000
and then increment it by 2 as out =out +2'b10
or
increment the out number by 1'b0 and then left shift the result by 1'b1
