Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
Chinese Proverb
You can use an ohmmeter to check the pins
I suppose you know the operation of NC and NO pins
Your description is correct.
The pins that have resistance are the coil pins.
From the remaining three pins one is common and will be shorted to the Normally Closed pin when you have no voltage applied to the relay while the common with the Normally Opened pin will be shorted when you apply voltage to the coil and the relay changes state.
The voltage applied in the relay coil depends and should match the relay rated voltage.
There is of course the alternative of checking the relay pinout in the datasheet of your device if the model number is known.
Alex
Your coil wires are fine, the coil only uses about 30-50mA so the wires width doesn't matter.
Use an insulating tape to cover the mains connections for security so that you don't touch them.
---------- Post added at 15:20 ---------- Previous post was at 15:19 ----------
I hope you have wired a switch before right?
don't connect both mains wires to the relay and short circuit them..
thanks sir..Yes, your connection is correct.
