[SOLVED] [Moved] Digital Input from PIC18f97j60
Mhadhu
Junior Member level 2
Hi all,
Am able to get a digital input at D_IN1. I am trying to check this using an LED at PORTJ. So what i do here is whenever the corresponding LED of D_IN1 goes high i should make an LED glow. My LED that corresponds to D_IN1 is glowing but the condition that is use to make PORTJ LED is not working. Can anyone correct my error here?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
#include <p18f97j60.h>
#include<delays.h>
#include<usart.h>
#pragma config XINST=OFF
#pragma config WDT=OFF, FOSC2=ON, FOSC=HSPLL, ETHLED=OFF
#pragma config WDTPS=256
#pragma interrupt interrupthandler
#define LED PORTCbits.RC2
void interrupthandler();
void function();
void data();
unsigned char a[10];
unsigned char ucCharBuff[10];
int i = 0;
int j = 0;
void main(void) {
    OSCTUNE = 0x40;
    TRISG = 0;
    PORTG = 0X40;
    TRISC = 1;
    TRISJ = 0;
    Open1USART(
            USART_TX_INT_ON & //Enabling USART
            USART_RX_INT_ON &
            USART_ASYNCH_MODE &
            USART_EIGHT_BIT &
            USART_CONT_RX &
            USART_BRGH_LOW,
            67);
    RCONbits.IPEN = 0;
    INTCONbits.GIE = 1; //Enabling interrupts
    INTCONbits.PEIE = 1;
    PIE1bits.RC1IE = 1;
    ADCON1 = 0X0F; // dISABLING ANALOG INPUTS
    //    RCSTA1bits.CREN = 0;
    Delay100TCYx(100000);
    ucCharBuff[0] = 0x34; // rfid tag code is stored in ucCharBuff.
    ucCharBuff[1] = 0x32;
    ucCharBuff[2] = 0x30;
    ucCharBuff[3] = 0x30;
    ucCharBuff[4] = 0x41;
    ucCharBuff[5] = 0x34;
    ucCharBuff[6] = 0x33;
    ucCharBuff[7] = 0x35;
    ucCharBuff[8] = 0x42;
    ucCharBuff[9] = 0x31;
    while (1) {
    Close1USART();
#pragma code interruptvectorhigh=0x08
void interruptvector(void) //interrupt vector
    _asm
    goto interrupthandler
            _endasm
#pragma code
//interrupt routine
void interrupthandler() {
    if (PIR1bits.RC1IF == 1) {
        PIR1bits.RC1IF = 0;
        for (i = 0; i < 10; i++) {
            a[i] = RCREG1;
        for (j = 0; j < 10; j++) {
            if (a[j] == ucCharBuff[j])
                function();
void function() {
    WDTCONbits.SWDTEN = 1;
    PORTG = 0X00;
    for (j = 0; j < 20; j++) {
        Delay10KTCYx(1000);
    PORTG = 0X40;
        Delay10KTCYx(1000);
        data();
    PIE1bits.RC1IE = 0;
    WDTCONbits.SWDTEN = 0;
void data() {
    while (LED == 1) {
        PORTJ = 0X02;
Re: Digital Input from PIC18f97j60
The problem is solved. I dint give the LED glow in correct place.
