[Moved] Difference Amplifier
flabbergastt
Junior Member level 2
Hi, first time posting an image, my apologies if I've posted it incorrectly.
I'm trying to get this difference amplifier working but it doesnt seem to be outputting what I want it to output. V1 = Vin V2 = -0.5v Rf=Ri, A=1 I want the output to always be Vin+0.5v so, Vo = (Rf/Ri) * (Vin-(-0.5))
Any help is appreciated, thanks!
Your schematic is large and easy to read.
I'm looking at M6.
Questions:
* Its icon appears unusual. It has the arrow pointing away from the center, to indicate it is a P-device. However that arrow does not then connect directly to the drain or source. It connects to the positive supply rail. And neither the drain nor the source go to a supply rail.
Is M6 a device found in the simulator library, or did you construct M6?
* C2 connects to M6 (its drain or source). It blocks DC in such a position. This would be a non-typical function. Is that its purpose?
C2 will pass very high frequency AC, but only for a few cycles until it charges to a maximum DC level. Then it will no longer pass AC. Is that its purpose?
