[moved] creating 50hz PWM using PIC16f877 on ccs c for Thyristor Firing
ABHI9868715910
Newbie level 3
Newbie level 3
DELHI
Hello Everyone this forum has been instrumental in my design work on FPGA/8051 and now PIC.
But Im stuck in a strange situation where iam required to read the status of External Interrupt and on every rising pulse I have to create a PWM of 50hz using Timer 0 to fire a thyristor.
Let me explain the circuit a little bit
Im reading the output from a zero crossing detector on PIN_B0 which is a square wave of 50HZ.
According to this signal I want to trigger my thryistor for Half wave configuration.
Im generating PWM using interrupt on timer1 and increasing the PWM using keys.
More over,if iam varying the "pwm_tm" value the whole PWM frequency is varying.
Please suggest!!
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
#include <main_timer0.h>
#define PWM_TIMER    20480     // duty cycle
#define PWM_OUT      PIN_C1
#define PWM_OUT1     PIN_C2
#define  Up    PIN_A5
#define  Down  PIN_A4
#define  max   PIN_A3
#define  off   PIN_A2
int1  pwm_so ;
int16 pwm_tm ;
#INT_EXT
void  EXT_isr()
clear_interrupt(INT_EXT);
#INT_TIMER1
void wave_timer() {
clear_interrupt(INT_TIMER1);
if (pwm_so) {
      // OFF
      output_high(PWM_OUT);
      output_high(PWM_OUT1);
      set_timer1(56536-pwm_tm);
   else {
      // ON
      output_low(PWM_OUT);
      output_low(PWM_OUT1);
   pwm_so = ~pwm_so;
void main()
{  setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);   // setup interrupts
   enable_interrupts(INT_TIMER1);
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_EXT);
   ext_int_edge(H_TO_L);
  pwm_tm=4000;//24536-19hz //4536-100hz
   while(TRUE)
   if(!input(Up))
   pwm_tm+=1000;
  output_d(0X02);
else if(!input(down))
     pwm_tm-=1000;
     output_d(0X04);
else if(!input(max))
     pwm_tm=0;
     output_d(0X06);
else if(!input(off))
     pwm_tm=4000;
     output_d(0X08);
 delay_ms(500); // 0.5 second delay to release the selected button
  }while(input(up) && input(down)  && input(max)  && input(off));
you are changing the timer value so it obvious that change frequency not duty cycle.You can use CCP module to generate the PWM.
look above for example
hello,
i think 50Hz frequency for PWM control is outside of spec of CCP module...
or decrease the FOSC ...
or you simply can use timers .. to built your commande.
