Genovator
Advanced Member level 2
Here is a code for a modified sinewave inverter I found in a website. Since I am not so good in assembly, I don't understand one thing here. In the last portion this code, a label has been called- "ACALL PULSE_TRAIN" but I found no such label (PULSE_TRAIN) in the program. I only found a label "PULSE".
Then what exactly this "ACALL PULSE_TRAIN" works here??? Is this code is wrong or my concept is??? My code is below:
;P1=INPUT P3=OUTPUT
;P1.2=BUTTON START P1.7=BATTERY CHECK
;P3.5=DRIVER1 P3.7=DRIVER2
;P3.4=BUZZER P3.3=LED
;INITIALIZATION (BEEP SHORT + BEEP LONG)
ORG 00H
ON: MOV P3,#20H; DRIVER OFF, BUZZER OFF, LED OFF
ACALL DELAI; WAIT 1/4 SEC
SETB P3.4; BEEP ON
CLR P3.3; LED BLUE ON
CLR P3.4; BEEP OFF
SETB P3.3; LED BLUE OFF
SETB P3.4; BEEP ON
CLR P3.4; BEEP OFF
;CHECK BATTERY CONDITION (LOW VOLTAGE = 2 X BEEP SHORT)
CEK: JNB P1.7,MULAI; CHECK BATTERY CONDITION (MULAI=START)
SETB P3.4; BEEP ON
CLR P3.4; BEEP OFF
SETB P3.4; BEEP ON
CLR P3.4; BEEP OFF
SJMP CEK
;INVERTER WAITING KEYSTROKES ON
MULAI: SETB P3.3; LED BLUE OFF
CLR P3.4; BEEP OFF
MULAI1: JNB P1.2,START; READ BUTTON START
AJMP CEK
;INVERTER ON
START: SETB P3.3; LED BLUE OFF
CLR P3.4; BEEP OFF
SETB P3.4; BEEP ON
CLR P3.4; BEEP OFF
;PWM GENERATOR
PULSE: JNB P1.2,ON; IF STOP PRESS BACK TO START
JB P1.7,ON; CHECK BATTERY CONDITION
PWM: CLR P3.5;
CLR P3.7;
SETB P3.5;
ACALL PULSE_TRAIN;
CLR P3.5;
CLR P3.7;
ACALL PULSE_TRAIN;
CLR P3.5;
CLR P3.7;
AJMP PULSE
;ROUTINE DELAI1
DELAI: MOV R1,#2
L1: MOV R2,#250
L2: MOV R3,#250
L3: DJNZ R3,L3
DJNZ R2,L2
DJNZ R1,L1
RET
