niranjan23
Member level 5
hi
I am using P89v51RD2 NXP's microcontroller IC. and also for assembly language programming I use Keil uVision4 simulator.
Problem is, the .hex file which is generate in Keil uVision4 is not work in above mentioned IC ,so I want any simulator software to convert assembly language program to hex file..and give solution for it...
thanku..
thanku..
