julian403
Full Member level 5
- Joined
- Feb 28, 2014
- Messages
- 254
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 18
- Location
- Argentina
- Activity points
- 2,105
Yes, it has low output. The supply voltage is +- 34 V.
yes, from the pin 8 to -34V. I think it can be because the value of Rf1, Ri and Ci. But I use the value that datasheet says. Following datasheet
Ri= Rf/ (Av-1)
so with Ri=1k , Rf= 22-k , the voltage gain is Av=23.
I fixed, i change R1 from 1 Kohms to 100 ohms. But another things, if higher the potentiometer higher power output ?
