[Moved]: AD7746 + Arduino Uno I2C
nanana_1011
Member level 2
Member level 2
0x90 = read address
0x91 = write address
If I use arduino uno to read the registers from AD7746, should I use 0x90 or 0x91?
Re: AD7746 + Arduino Uno I2C
The link below has some source code that may help you.
If you're trying to read from the AD776, assuming you have your register values correct you should use 0x90.
TC
Hello!
For I2C in arduino, the register is 1 byte.
If I have another IC having 2-byte register, how can I communicate with it using arduino?
You have to send the two byte address. I guess high byte first and then low address byte. Check the device datasheet. What device it is ?
Also, if I retrieve value from IC, it is 2 bytes.
Do I save the value and obtain the high byte and then low byte?
LaTeX Commands Quick-Menu:
