[Moved] A problem : pic16f877a with servo motor
Ibrahim El Ayas
Newbie level 2
Mansoura - Egypt
Alsalamo Alykom
hi
i want to make a servo motor rotates by an angle
the PWM code is
while (1)
          portc.f0=1;
         delay_us(2000);
          portc.f0=0;
        delay_us(18000);
you must change these values to gain an angle
i want to know for 1 degree how much Hi period does it take ...
Thank you ...
Re: A problem : pic16f877a with servo motor
Look at the specs for your servo. The manufacturer should give you information regarding max/min pulse widths for max/min angles of rotation.
thanks enjunear for your help :)
but my problem is that the delay function did not work .. i am thinking about timers ...
What you need to do is take the normal rotation of a servo which is 180 degree.
Now take the pulse width for the rotation which is normally 1ms. ( the 2 ends are 1ms and 2ms).
So from the 1ms position to move 1 degree the pulse needs to (1*(1/180))+1ms = 1.006ms approx (1006us).
These calcs are based on a normal RC servo.
HTH
