mount a second hard drive in scientific linux
tompham
Full Member level 2
Full Member level 2
usa
Hi all
I want to mount a secodary hard drive in scientific linux:
This is information of hard drive when i type fdisk -l
Disk /dev/sdc: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Thanks
Hi flanello
Thanks for your suggestion. I already mounted my second hard drive to linux sysem. I have scientific linux install on primary drive and want to have windows os on second one. Do you know how to do it? Someone told me I can disconnect linux hard drive and install windows on second one and connect back after finish installation but I m not sure this method work or I will lose information in linux drive?
Thanks a lot
It could work. But the interesting part is how can you choose what system would be started?
The other way round works easily: Install windows and then linux. Linux will detect the windows and create a menu where you can select what will be started.
Ask this question in a linux forum, for example in the scientific linux forum.
There will be probably more experts with regarding this topic.
