motor' pwm control according to switch value
nudrat
Junior Member level 1
hi everyone!
I want to start and stop pwm(which drives a motor) according to the value of switch.
Motor is on portc(RC2) and switch is on RB0.
I am using pic16f877a and software is mikroc.
Can anybody help me in writing c code?
did you check HELP of mikroc?(search PWM)
Take a look at the help section in mikroC and the PWM library functions. Are you clear regarding how to check the state of an input pin?
After taking a look at the library, please come here and I'll help with the coding.
Tahmid.
@tahmid thanks.
I generated PWM on portc and motor rotates well.
My problem is that i am using an NPN transistor as a switch on PORTB.0. and want that if value of NPN switch is 1 the motor starts and if its value is 0, motor stops.
I tried so much but once motor starts it dont stop weather i change the value of switch.
Can you show schematic; your problem may be there (transistor doesn't bias ?,Check V at input pin of uC).
May be your code has a bug. It doesn't response to input.
Thanks,
In the code, to stop PWM, use
PWM_Stop()
or
PWM1_Stop()
, whichever is necessary.
Hope this helps.
Tahmid.
