Motor Position Sensor
lake_of_fire
Newbie level 5
Hi
I need to be able to count the pulses from an optical encoder connected to a quadrature clock converter that is then connected to a PIC18,
I was going to count the pulses using timer0, is there a way to count down these pulses when the motor direction is reversed so that motor position can be monitored
The converter i plan to use is an LM7184 which provides pulses and a digital up/down line.
Thanks for any advice
goldsmith
Advanced Member level 5
Tehran - IRAN
Hello lake of fire !
how can i help you ? what is your problem ?
Best Wishes
Goldsmith
lake_of_fire
Newbie level 5
Hi I would like to know if I can use the time0 to count pulses up and down?
Alternatively I could use the grey code sequence to increment and decrement a counter
