Engin_nerd
Newbie level 1
pic16f88 mikroc
I'm stuck on this project and I believe something is wrong with my code. I'm using a black/white wheel encoder with 24 tics on it, a infrared reflective light sensor (to detect the black and white tics), a dc motor, and a quadruple half h-driver to control the motors movement.
I want the motor to move from the black tic, to the white tic and stop. This is the first step in my project and im I'm having problems with the motor stopping at each of these tics. The motor can turn over 360 degrees before it stops. Here is my code. If any one has any ideas, I'm very new to programming so any help would be appreciated. I attached my code in a notepad file
Added after 6 minutes:
***sorry my file didnt upload, here is my code***
#include "HEADER1.h"
//PORTA FOR SENSOR
#define DETECT BIT2
//PORTB FOR MOTOR CONTROL
#define CW BIT0
#define CCW BIT1
#define STOP (~BIT0|~BIT1)
//parameters
#define deg15 1 //tics for 15 degrees
unsigned char sensor;
unsigned char lastvalue;
unsigned int count;
void countdown(char source, unsigned int tics){
count = 0;
if (source == 'R'){
PORTB = CW;
else if(source =='L'){
PORTB = CCW;}
else{PORTB = STOP;}
lastvalue= PORTA&DETECT; //initialize before compare
while(count<tics){
sensor = PORTA&DETECT; // poll sensor first time
if(sensor!= lastvalue)//change detected
Delay_ms(10); //wait 15ms
sensor = PORTA&DETECT; //confirm change
if(sensor != lastvalue)
if((sensor&DETECT) != (lastvalue&DETECT)){count++; }
lastvalue = sensor;
PORTB=STOP;
void clockwise(){
countdown('R', deg15);
void counterclockwise(){
countdown('L', deg15);
void main(){
ANSEL =0; //turn off ATD
TRISA = 0xFF; //SENSOR ONLY INPUT
TRISB = 0xFC; //MOTOR OUTPUT
clockwise();
Added after 7 minutes:
The compiler I'm using is MikroC.
Added after 38 seconds:
//PORTA FOR SENSOR
#define DETECT BIT2
#define CW BIT0
#define CCW BIT1
//parameters
unsigned int count;
count = 0;
if (source == 'R'){
PORTB = CW;
PORTB = CCW;}
else{PORTB = STOP;}
while(count<tics){
lastvalue = sensor;
PORTB=STOP;
void clockwise(){
void main(){
clockwise();
