Motor Commutation Sequence
venkat9chinthapalli
india
Hello .....
I have a query regarding commutation of 3-Phase BLDC Motor.
In my design i have a 2pole 3Phase BLDC Motor and H-Birdge for the commutation of motor and the sequence is as follows
Sequence 1 Switching ON - HS_V and LS_W Mosfets
Sequence 2 Switching ON - HS_U and LS_W Mosfets
Sequence 3 Switching ON - HS_U and LS_W Mosfets
Sequence 4 Switching ON - LS_V and HS_W Mosfets
Sequence 5 Switching ON - LS_U and HS_W Mosfets
Sequence 6 Switching ON - LS_U and HS_V Mosfets
Each sequence is used to rotate motor by 60Deg.
So my question is if i need to goto 85Deg how the sequence would be
