akh_power
Junior Member level 1
I am using the Cree C2M0025120D device for my research purpose. I have found recently that the datasheet of the device now shows different specifications compared to the previous datasheet of the same device. The link for both the datasheets are given below :
Old : https://www.farnell.com/datasheets/2048144.pdf
New : https://assets.wolfspeed.com/uploads/2020/12/C2M0025120D.pdf
Is it common to have device with same part number to gave different characteristics? Many important parameters of the MOSFET such as continuous drain current, Coss, Ciss, Diode forward voltage drop, Reverse recovery charge, Turn on time, Turn off time etc have changed.
I got into trouble when I had to change one of the MOSFET of a full bridge circuit which was using old C2M0025120D mosfets. Because, I had to change it with a new C2M0025120D mosfet and I was not aware of the change in the MOSFET characteristics. The turn-on time was drastically different (more than 500ns) for the 27 Ohm external gate resistance that I chose.
I believe manufacturers should not release products like this.
