Rehma Anjum
Newbie
I am trying to run the MOSFET IRF3710 as low side Mosfet. As I increase the frequency above 5khz, the falling edge of the waveform starts getting slanting (as shown in the attached video file). After 22kHz it enters into Continuous Conduction Mode. I want to run the MOSFET on at least 30kHz and as I have to run the MOSFETs in H-Bridges for Dual Active Bridge Converter, so I can not work on lower frequencies.
I am using a 3.2k ohm resistive load. I have tried using multiple MOSFETs to understand the issue such as IRF540, IRF3205, 20N60C, IRFP460, F22N60E and IRF840 but the same happens with each one of them at high frequencies.
I also gave a direct PWM signal at the gate (without gate driver), but the same issue persists.
I have attached the circuit design in the attachment. Kindly help me figuring out the problem. Thanks
