Mosfet input impedance
namel
Newbie level 6
I want to know how to measure input/output impedance of a device. Can I just do the s parameter analysis and then find out z parameters? Will that be enough?
For manual analysis, you can suppose it is infinite.
For more accuracy, you can simulate it with your process model.
i want to simulate it but not sure what would be the correct approach. Please help me, thanks
Please add a voltage source for gate and sweep the voltage and check the current. Obtain impedance with V/I.
This is DC impedance.
If you want AC impedance, you need to sweep the frequency for every operating point.
Dont I have to put any dc bias in drain terminal?
You can have dc bias for drain as the application.
Reactions: namel
    namel
I have built a circuit with a small ac signal imposed on the dc bias voltage in the gate of the MOSFET and also a dc bias voltage at the drain. It does give me some result. But when I do the s parameter analysis on that device with same configuration and same bias conditions, the s parameter value does not match with the previous one.
Should it be an issue?
s analysis also have same operating point?
Operating point impedance is not worth much in a switching FET. The
gate impedance gets real "interesting" once the drain begins to slew.
Small signal analysis doesn't tell you much useful there. Even a linear
MOSFET amp is driven more by Cdg than lumped Cgg, without the
drain realistically loaded and free to move you'll get a bogus idea of
what the gate looks like to the driving source.
Reactions: KerimF
    KerimF
@dick_freebird I have not fully understood what you have said but if it is a matter to bias the mosfet in saturation region I did that, still there is discrepancy in the results.
@leo_o2 in s parameter analysis you can bias the MOSFET and then run the analysis
