justerr
Newbie level 2
- Joined
- Jan 14, 2014
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 20
Hi everyone. I have built this AC-DC converter, but can't get it working properly. I tested it in simulator and it worked just fine, but on a breadboard (or on PCB) I have had problems. The biggest problem is that the pulse at MOSFET's (Q12) gate gets rounded, which heats up the MOSFET. Or at least I think that's the main problem why the MOSFET heats up.
The idea here is that the LTC1771 gets its power initially through R69&R71 and then starts controlling the MOSFET with the help of the transistors. The pulse at PGATE of LTC1771 is really sharp, but gets rounded after T2. Driving the transistors and the MOSFET should be strong enough, so it shouldn't cause this, right? Or what am I missing here? Otherwise the circuit is working fine. Just that you can't run it very long without blowing up the MOSFET
Any ideas? Or does anyone has any good application notes, etc.. about this subject, I could look at?
