mosfet for 78xx current booster
palesha
Full Member level 2
current booster mosfet
All the circuits show Transistor for current boost with 78xx 3 pin regulator. Why don't they use mosfet instead of Transistor.
78xx mosfet
8) using MOSFET as a pass element is not straight forward, there is a fundamental differance in the way both devices work. a transistor is a current driven device and mosfet a voltage driven device. in case a N channel mosfet is used as a pass element a positive voltage(5 to 10 Volts depending upom type) is required with respect to the source, in which case a voltage multiplier or a voltage booster will be required, which will complicate the design of regulators.
