Do you think it will work with mosfets ?
Nobody knows what MOSFET you are talking about.
--> you need to read
both datasheets and compare the values.
But generally I´d rather use a driver that is suited for MOSFETs. (I assume there is a good reason why they build different drivers for MOSFETs and IGBTs)
You have a problem with the units:
"15KhZ" --> 15kHz (all uppercase and lowercase reversed)
"66uS" --> 66us (66uS means 66 microSiemens which is the same as 15151Ohms)
"0.8nS" --> 0.8us = 800ns
Try to use the correct units to avoid confusions.
Klaus
