rsklan
Junior Member level 1
"I am designing a brake circuit for a motor driver. This circuit must use an op-amp and a MOSFET. A comparator is used to detect the back EMF and the bus voltage, and based on these conditions, the MOSFET is supposed to turn on or off.
I have completed the simulation and circuit design, but I encountered a problem. When the back EMF voltage is greater than the bus voltage, the MOSFET turns on as expected. However, when the back EMF drops below the bus voltage, the MOSFET does not turn off. I can't control the gate voltage of the MOSFET.
I have experimented with pull-up and pull-down resistors, and in the simulation, I get the correct result. The calculations are accurate, and the circuit design is correct, but I can't get it to work properly in practice. Can you help me?"
