Mosfet drain-source voltage
Nizar_Ib
Member level 1
I have the circuit below, when I have voltage on gate-source (~4.3V) I get voltage (~2-4V) on V12 (drain source).
why that happened? I don't face this issue on another circuits with same parameters. I have 12 circuits near each other, are totally separated from each other.
in another way of question, in which cases the FET gives me voltage on DS when I have voltage on GS?
Your left side voltage source is called Vgs, but in your circuit it is V_gs + V_shunt.
If it is called gate-source, why isn't it onnected to the source?
I'd rather connect the right side supply across the shunt.
Klaus
Klaus
Hi, sorry, here is my original circuit:
Your VS looks like a capacitor or a battery. What is it?
a VS is a power supply which I want to test.
Sounds confused. In your simulation schematic, "V12" is a drawing item without circuit functionality. If you want to simulate a power supply, you'll place an actual voltage source.
What does it mean "I get voltage (~2-4V) on V12"? How do you measure it? Are you talking about simulation or a real circuit?
I'm talking about a real circuit.
when I have voltage on Vgs I get voltage where you see V12, I measure it by DMM.
Most likely explanation: drain-gate shorted, either defective MOSFET or external short.
Klaus
in my circuit the "Vgs" is a regulator.
where sould I connect the negative side? directly to the source of the FET or to the ground of the circuit?
See the name: It is called V_GS. Therefore I assume one leg is connected with Gate, the other with Source.
I don't know what the circuit is for and who named it V_GS...therefore it's just an assumption.
Btw: A regulator usually needs a feedback path...but I don't see any.
Klaus
