[SOLVED] MOSFET control problem
dxtr
Member level 3
Hey everybody
i wanna simulate a chopper using mosfet but i can't get it to work.
i used NE555 to generate pwm signal
here is the result
why i don't get a a chopped signal between 0 and 100v
The scope trace alternates between 96.7 and 100.2 V. I believe you expected it to alternate between 0V and 100V.
I think it will resemble that if you were to add a load, with the other end connected to zero ground.
Since a voltage will appear across it, this may change the gate-to-source differential...
which may change the internal resistance of the mosfet...
which may change the voltage on the load, etc.
Reactions: dxtr
    dxtr
Try connecting the Source pin of MOSFET to gnd. Right now i can't figure where it's going. Whats the <arrow> and '+' symbol mean ??
And a Voltmeter is certainly not gnd.
And of course some sort of load R on the drain going to the supply positive.
Reactions: dxtr
    dxtr
Thank you , it works now :)
another question , is there any circuit to trace the average of the chopped signal ?
..is there any circuit to trace the average of the chopped signal ?
you can try your voltmeter (an actual physical one.. not a simulated one) between Drain and Gnd. Set it to read DC volts. This will give you an approximate idea of the average voltage.
Reactions: dxtr
    dxtr
thats good , but i want the average value , i want a physical circuit if possible !
If you mean a simulated physical circuit...
Add a high ohm resistor and a low value capacitor, to get an averaged reading.
Screenshot:
The 10V pulses come at 70% duty cycle. The average is 7V.
Screenshot:
Thank you so much :)
